HEAD CC EXPERTS IN HERE...NEED HELP FAST!!!
Stock 5.7L heads are 67cc's
Mine measured out to be 61.6cc's...
which means they are milled to about .030" right??
11:1 compression... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
And these heads were supposed to be stock compression... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Or go to a thicker HG from cometic, but you will only gain 20 thou from that. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I would rather sell the heads, get 6.0L, and just get boost pistons...and still have a safe C/R
Stock 6.0L heads, diamond boost pistons, stock rods, ARP rod bolts, and new bearings would be what I would do on a budget.
Justin
Saw your car on Saturday. I'd think if you didn't damage your bottom end you might be able to get away w/ a set of stock CR 6.0 heads?
I think the dished Diamond's are supposed to be around 9.5 CR. Would probably be lower with the larger chamber LS1 heads. You'd really be able to crank up the boost with those.
Good luck w/ your Hawk.
So...
If I did go with low compression pistons, how low (C/R wise with the piston) would I have to go to get at a safe level, if I can't sell the heads, this is what I'm doing..
<strong> BigBos, have you considered keeping hi compression and running boost anyway? The more compression the less boost motor will be able to accept. This way driveability is good in non boost driving and full throttle out put shoulkd be great also. Yes this will require proper timing and tuning to work good but why not run it like this? Anyone try this? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">11:1 is a pretty high bench mark to start with boost. He would have to keep the boost so low that it would make FI negligable
3 psi = 13.0
4 psi = 14.0
6 psi = 15.5
Now, if he was building an all-out race motor, then I would agree to keep the compression high. But unless he has a 110 octane pump in his backyard.....
Just my .02
<strong> Well these heads are anywhere from 10.7:1 compression to 11:1 compression which is high...
So...
If I did go with low compression pistons, how low (C/R wise with the piston) would I have to go to get at a safe level, if I can't sell the heads, this is what I'm doing.. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You are going to have to run at least a 15 cc dish piston to bring the compression down to 9.5. Here are some dish sizes to get you started.
10cc = 10:1
12cc = 9.7:1
14cc = 9.5:1 (minumum)
16cc = 9.3:1
18cc = 9.1:1
These are all for a stock motor with 61 CC heads.
Good Luck,
Kevin
cheapest and fastest solution in my head anyway
Custom flat tops with pins - $727.00 for the set
Custom domes with pins - $777.00 for the set
Custom dish with pins - $757.00 for the set
The prices above are with the good H13 tool steel wrist pins also.
Let me know if there is anything I can do for you.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
