ls7 or caddy lifters?
Old Feb 1, 2007 | 09:05 PM
SPRAYED 01's Avatar
Default ls7 or caddy lifters?
Wondering which of these lifters i can use in my ls1. Would any need modifications? Also part numbers would be great.
Alex
Old Feb 2, 2007 | 06:45 AM
PREDATOR-Z's Avatar
You can use both, look in Katech's web for Cadi's and SDPC for LS7
Old Feb 2, 2007 | 07:38 AM
chris mac's Avatar
i went with the LS7s for my heads/cam build... i got them from my local chevy dealer for $109. you might call around some of your local dealers and see what they get for them.
on a side note... you'd be wise to look them over VERY closely before you give them their oil bath! i was checking them all out when i noticed a chip in the edge of one of the BRAND NEW lifters. upon closer inspection i noticed a crack going from the edge of the lifter (the thinnest part at the corner of the roller) up the lifter body about 3/8" and back up the lifter, making a "y" looking crack... just a heads up for ya to check EVERYTHING over very well!!!
good luck
mac
Old Feb 2, 2007 | 08:35 AM
thehammer69's Avatar
You will have to look to SDPC for the caddy lifters also. I seen a post yeaterday with somebody wanting to know where to find them and Katech directed them to SDPC.
Hammer
Old Feb 2, 2007 | 09:39 AM
PREDATOR-Z's Avatar
Super, that makes it easier then.
Old Feb 2, 2007 | 10:12 AM
Cantalope Kid's Avatar
LS7's lifters are fine...the Caddy lifters are for high rev. people or those with high horse power serious durability needs. They are also 2X $$$ as much as the LS7's!
Old Feb 2, 2007 | 10:35 AM
SPRAYED 01's Avatar
Any one have a part number for the ls7s or should i just ask for lifter for a 07 z06.
Old Feb 2, 2007 | 10:43 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Sprayed, when you call and ask for me, I know the part number
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 2, 2007 | 11:52 AM
DJMRTS's Avatar
From what I'm understanding, the new GM replacement lifter for all LS1, LS6, & LS2 applications is the LS7 lifter. All previous versions are no longer being manufactured. I heard that the Caddy lifters will also quiet down the valve train a bit.
Old Feb 2, 2007 | 12:04 PM
JimMueller's Avatar
I ordered the Caddy lifters thru TSP, although I don't know where they obtained them.
Old Feb 2, 2007 | 12:18 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
What is the advantage to the LS7 lifters compared to stockers?
Old Feb 2, 2007 | 12:39 PM
JZ'sTA's Avatar
My question exactly. Stock lifters are fine. We use the caddy lifters when using a highly aggressive spring/cam setup.
Other then that save your money and go buy yourself a lapdance.
Old Feb 2, 2007 | 01:15 PM
pdd's Avatar
pdd
sounds like a plan
Old Feb 2, 2007 | 01:23 PM
DJMRTS's Avatar
LS7 lifters are suppose to perform better at higher RPMs than the old style stock lifters.
Old Feb 2, 2007 | 01:57 PM
SPRAYED 01's Avatar
I had to take the heads off to resolve some other issues (bent valves) and i figure since im in there for 120 why not. It would suck to have a lifter problem and then have to take the heads off again and spend 150 for cometic gaskets.
Old Feb 5, 2007 | 09:49 AM
Marc '99T/A's Avatar
What would be better for a fairly high lift LSK cam? I won't be spinning it past 6400.
