Pushrod length
Old Feb 2, 2007 | 07:49 PM
'02 WS6's Avatar
Default Pushrod length
I'm going to order the LS6 heads and cam pkg from TSP w/ the 233/239 cam. i know that they recommend running a 7.350 on the ms4's to give it a little more needed clearance. i'm wondering if it would be wise, with my cam choice being somewhat smaller than the ms4, to run 7.375 to give my valvetrain a little more clearance or make it snug w/ the standard 7.400? any input is appreciated. thanks
james
Old Feb 2, 2007 | 07:51 PM
brad8266's Avatar
You need a longer pushrod with a cam setup not a shorter one. The base circle of the aftermarket cam is smaller, thus requiring the longer rod to maintain proper preload.
Old Feb 2, 2007 | 07:58 PM
'02 WS6's Avatar
ok, maybe i misinterpreted the info on the pushrods. so it's probably wiser to stick with the 7.400's then. thanks for the info brad8266.
Old Feb 2, 2007 | 08:02 PM
ls1muscle's Avatar
7.400 or 7.425, either will work
Old Feb 2, 2007 | 08:56 PM
'02 WS6's Avatar
we'll TSP doesn't have an option over 7.400, so i guess im going with those!
Old Feb 2, 2007 | 09:01 PM
brad8266's Avatar
comp makes rods longer than 7.4
Old Feb 2, 2007 | 09:21 PM
'02 WS6's Avatar
are they sold through tsp? and would it be your opinion for me to run some longer than 7.400?
