Do I need different pushrods for f13?
Old Feb 2, 2007 | 11:08 PM
nomorews6's Avatar
Default Do I need different pushrods for f13?
I have a tr224 now, and the previous owner just said it has 'hardened pushrods'. Do I need to get different pushrods to run the f13? I was running stock 98 heads before and now i will be running some tsp prc 5.3 2.5r heads (63cc)
Old Feb 2, 2007 | 11:10 PM
thehammer69's Avatar
the only true answer is maybe, anything else is a guess. You need to measure to find out for sure.
Hammer
Old Feb 2, 2007 | 11:27 PM
Dustin 98TA's Avatar
If the heads havent been milled it will be fine with the stock length pushrods.
Old Feb 2, 2007 | 11:56 PM
nomorews6's Avatar
they are 63 cc tsp 5.3 2.5r heads ...
Old Feb 3, 2007 | 06:41 AM
PREDATOR-Z's Avatar
They will be fine.
Myself I would run 7.425s
Old Feb 3, 2007 | 08:17 AM
nomorews6's Avatar
is there more horsepower to be had to run a different pushrod?
Old Feb 3, 2007 | 08:35 AM
PREDATOR-Z's Avatar
That is still debatable (preload effect on HP)
The main issue is to run in the .080>.100 preload on the stock lifters. Less will result in a noisier valvetrain.
