Do the 243 heads bolt right on to my 98ls1??
Old Feb 3, 2007 | 06:36 PM
1fastz's Avatar
Default Do the 243 heads bolt right on to my 98ls1??
I just pulled my motor out and im replacing the crank and bearings and all that. I already have a cam, and im thinking while i have the chance, i should upgrade the heads as well. I already ordered all the bolts and gaskets needed to put the engine back together. however, im thinking about getting a set of 243 heads, willl these heads just bolt right onto our motors? or do i have to get different head bolts or different gaskets or what? let me know!! thanks guys
Old Feb 3, 2007 | 06:41 PM
Proud2bSS's Avatar
Exact bolt on.
Old Feb 3, 2007 | 06:46 PM
blkbird's Avatar
Yes, they will bolt right up.
Old Feb 3, 2007 | 06:51 PM
bad6as's Avatar
arnt the valve covers differant?
Old Feb 3, 2007 | 06:56 PM
1fastz's Avatar
im not sure but i think ive read that to use these heads on an LS1, you would also need an LS6 intake (to match the intake ports) and throttle body. if you have a ’97 or a ’98, you need to change their valve covers becuase they use perimeter bolts instead of center bolts, and the coil mounts are different... is this true????? for my 98 ls1 camaro application???
Old Feb 3, 2007 | 07:04 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
heads, intake with work every well on your LS1 - look at my sign
thanks
Bill
Old Feb 3, 2007 | 07:07 PM
DONAIMIAN's Avatar
Only thing that needs to change with thoes heads are the valve covers. Basicly, look under the hood in the formula thats in your sig.
