cam swap done, now oil press. problem
Old May 26, 2002 | 08:14 PM
tigertat's Avatar
Default cam swap done, now oil press. problem
Just finished putting in a C1 cam and now my oil pressure is 20-40 psi, 15-20psi lower than before the swap (it was normal range before). The only thing that was changed from before was cam, pushrods, Cloyes timing set, and went to dino oil for break in period. Has anyone had this problem? The car is a 98' with 95k <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> miles.
Old May 27, 2002 | 09:33 AM
SSHOTROD's Avatar
Default Re: cam swap done, now oil press. problem
check the oil pressure switch, proper connection, and if that doesnt work get ready to pull that baby(pump)
Old May 27, 2002 | 10:22 AM
Smoke_ur_5.0's Avatar
When you pulled the oil pump to put in the timing chain you sure you got that pesky little O-ring back in where the pickup tube feeds to the pump?
Old May 27, 2002 | 08:00 PM
wizkid's Avatar
Install Director
I bet the oring is the cause. It takes a few minutes to get that pump back on making sure the o-ring seats properly.
Eric
Old May 28, 2002 | 12:09 AM
tigertat's Avatar
That is a good question Smoke, I'm not sure, was thinking about that today. My friend pulled the pump while I was doing some other work to the car. I guess I should ask him, but if I need to pull the pump again, I will be putting a new one in.
Old May 28, 2002 | 02:11 AM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by wizkid:
<strong>I bet the oring is the cause. It takes a few minutes to get that pump back on making sure the o-ring seats properly.
Eric</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am like the wizkid chech to make sure the ring is in and in perfect condtion.
Old May 30, 2002 | 04:50 AM
roy's Avatar
roy
Yep
Oil pump o-ring . Ibe willing to make a soda bet on that is the problem.
Old May 31, 2002 | 12:34 AM
JohnR's Avatar
My Dr.Pepper says that the o-ring is missing. You might want to just buy another one in case you can't find the original. It will be a PITA but you gota check it!
Old May 31, 2002 | 05:00 PM
amos511's Avatar
Hey, im the freind that put the pump back in. We were going to replace it this weekend, but tat was in a motorcycle wreck and will be in the hospital for a while. Im a ford guy ( sorry for the bad laungage ) and i would like to fix it so that when he is able to drive his car it will be done. ive posted earlier the same ? , but maybe you guys can help. What pump should i get, tat said to get one from a 01-02 Z. But who sells them and which one should i look at getting. Thanks for your help.
Old May 31, 2002 | 06:26 PM
badls1's Avatar
just do to dealer and get one. now all of the oil pumps are LS6. i wouldnt get the ported one. just get a new one from the dealer new o ring, and i would put just a little bit silcon on the block and the pump around the oil passage way.
