white smoke after TR 230 cam....
Old Jun 5, 2002 | 05:57 AM
black00WS6's Avatar
Default white smoke after TR 230 cam....
Well I had a T1 cam on my car with a MAFT on it. I took off the MAFT and swapped the new TR 230 cam for the T1. Now when I gun it, white smoke puffs out the back of the car. I assume this has to do with the A/F ratios? I'm tuning my car this weekend with LS1Edit so hopefully that will work. Doesn't white smoke mean too lean?? Or would it be a blown gasket?? Even though it just started this after the install?!? I am thinking it is one of these reasons...
1. I broke a valve cover bolt off and used some west virginia enginuity to fix it (I'll be fixing that this weekend)
2. we lost a water pump bolt, so there is a bad seal around one of the holes.
3. I took an A-Tap run last night, and my LTtrim's were about -9%, and my o2's at WOT were about .95. So since I am running rich, the computer is over compensating too much.
<small>[ June 05, 2002, 06:07 AM: Message edited by: black00WS6 ]</small>
Old Jun 5, 2002 | 06:41 AM
VINCE's Avatar
Shorty Director
Default Re: white smoke after TR 230 cam....
Sounds about right.. So you are running TR230 what?
Old Jun 5, 2002 | 06:46 AM
VINCE's Avatar
Shorty Director
By the way.. What gears are you running. I remember we had similar old setups.. Both changed cams..
Old Jun 5, 2002 | 06:48 AM
black00WS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VINCE:
<strong>By the way.. What gears are you running. I remember we had similar old setups.. Both changed cams..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I still have the stock gears, I'm planning on a 12 bolt next year so dont really want to waste the $$ for a set of 4.10's or 4.30's in my stock rear end.
the 230/224 .569/.563 111 LSA TR cam (specs were actually .571/.563 110.3)
<small>[ June 05, 2002, 06:50 AM: Message edited by: black00WS6 ]</small>
