Dyno Graphs & Flow Numbers - MTI LS6 X1
There are too many choices, but I want to shift at like 6600-6700
That said, Lou, I am a serious drag racer and would be perfectly willing to try out your free G5 h/c package!!! <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Man, I have no shame. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>I'm so confused on what kind of cam to buy....what is the BEST possible motor cam to buy??
There are too many choices, but I want to shift at like 6600-6700</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It is very confusing isnt it? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Tony...I swear, MTI never sleeps. Those are great numbers <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ June 05, 2002, 07:40 PM: Message edited by: DevilBird ]</small>
We have about 20 cars out there now with this package, and you must ask yourself which power curve you would think is better. Plot the torque numbers at every 500rpm from 3000 to 6400. What do you see?
This was at a dyno day at LGM, with full exhaust, A borla Stinger on a C5 Corvette with NO pulleys, No cats, and a stock TB, and our own G2 air lid.
If some of you are going to disparrage the G5 package, you need to see the G5 graph next to what is now considered to be the new ground breaking discovery. Now someone needs to post the Thunder reverse split to check it out also.
And if any of you all think the G5 is such a "Large" cam, you will see that the graph shows that it is just a "Powerful" little old cam.
Later.
Lou Gigliotti
<small>[ June 05, 2002, 12:23 PM: Message edited by: LG Motorsports ]</small>
For instance, I am gearing up to do heads/cam on my Z28... I already have the SLP headers (yeah, yeah, I have had them for over a year...), which as many of you know come with a 3" Y-pipe. However, that Y-pipe, as delivered from SLP, is dual 3" into a single 3". So I bought a Flowmaster dual 3" into a single 4" Y to replace the dual 3" into a single 3" Y that is there now. I ordered a Mufflex 4" on Monday.
If you do a little bit of math, you can see that dual 3" pipes offer damn near as much surface area as a single 4". For what I am doing (heads/cam on a stock short block), I think that exhaust system will flow well enough to give me within 5 RWHP of the same setup running open headers.
Now Terry, why would you say that? I didn't hear you make any comments about the MTI graph.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The torque spike looked to be over a more narrow power band (4500-5000rpm), while the MTI torque spike is over a broader power band (4500-5500rpm). My experience tells me that is indicative of running open headers, but this is just speculation on my part.
Torque aside it's amazing how similar the power bands looks. If I could only pick between these two setups I'd take the LG setup because it uses less expensive LS1 heads and comes on a lot stronger at 5000rpm.
Of course I consider myself an amateur tuner and want to try a few different tricks on my setup. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ June 05, 2002, 12:23 PM: Message edited by: Terry Burger ]</small>
I completely agree with Lou's philosophy on torque wins races and hp sells motors, and the peak torque numbers that I have been seeing from the G5 cam are quite substantial. But until timeslips are being posted that represent the dyno numbers, the cam is hardly proven, and to even insinuate that it is superior because of high torque numbers on a dyno sheet isn't very fair.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Not sure on the advance data. I'd expect that it does have it ground in since all of the other MTI cams do </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tony: does MTI typically use 2 or 4 degrees of advance?
Personally I think TQ sells car (the famous V8 low end throttle response) and HP wins races (show me a low revving NASCAR or Indy car) but that is a debate for another thread. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
BTW, one of the LG G5 heads/cam Vettes that pulled 410 ft-lbs torque at LG also dynoed at MTI and only pulled 383 ft-lbs on the MTI dynojet. So, its very hard to compare dyno numbers from different shops in my opinion. I think the guy's name was Randy G.?
Lou, you definitely need to build a drag car!! Either that, or I can test your stuff out on my GMC truck (just kidding <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ). Seriously, we have a ton of excellent candidates here in Texas on this site.
Tony
Look for new times on the Thunder Racing Z28 Special this weekend.
<strong>I still have yet to see any stellar ET's from cars running the G5 cam, for whatever reasons. I am not knocking the cam by any means because I know it is relatively new. However, comparing the G5 cam to the X1 cam and then saying "note the torque," well that is all well and good, but where are the timeslips that represent that massive amount of torque? So the G5 cam has still yet to be proven as well in my opinion.
I completely agree with Lou's philosophy on torque wins races and hp sells motors, and the peak torque numbers that I have been seeing from the G5 cam are quite substantial. But until timeslips are being posted that represent the dyno numbers, the cam is hardly proven, and to even insinuate that it is superior because of high torque numbers on a dyno sheet isn't very fair.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hopefully I can get my butt to the track and get some numbers. I just hope at the same time there are some other people there with different setups with about the same numbers .. any different comparisions would be pointless since there will be a temp. diff as well as altitude differnces... (not to mention there is always driver differences).
You can't go by the track alone for comparing performance.
With just a lid, the best my driving could muster (3 times to the track and 6 runs total) was a 13.2x @ 107.7 mph (good weather).. If with this setup I (as the driver) can go 12.5x @ 113 or 114, I'd be estatic .. that would mean I picked up .8 and 6 mph with just the addition of cam, headers and pulley. I expect this will be in alot HOTTER conditions as well. I hope to get the track within the next month ... we will see what happens.
Crowley
The last run I made at MTI the car had detonation and floated the valves because the pcm was set wrong. We took some timing out and added the X Pipe to the rest of the G5 package and got the power up to a consistent 431/410. I have generated these numbers on LG's and Ed Wright's Dynojet. Which is the same as MTI's. All of them are inground and all were reading corrected numbers.
At any given time if a car is out of tune, it can give off poor results. Jeff knew there was something wrong with the car and lifted to save my motor. Even so, the HP was fine and since we added the X pipe and changed the programming, we have been consistently in this range.
So, Nineball, don't use my name if you don't know what you are talking about. Why are you putting down this package when it is consistent with the numbers of MTI's H/C setup? do you hear LG putting down MTI? I don't. I have the highest regard for both of these tuners and I have the results from both to support my confidence. Do you have the same level of experience with them both?
<strong>I personally would rather stick to the subject.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As a prospective heads/cam buyer, this debate interests me very much. As long as it stays civil and doesn't turn into a childish flame war, this could be very helpful for prospective customers. I'd very much like to hear all sides of the story.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"><strong>I will let you know who email Tony with his feelings.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do what?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"><strong>Back to the reverse split and what we think the future of this cam is going to be. Will this cam benefit any H/C setup?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You mean will ONLY an increase in intake duration, intake lift, and a lower LSA benefit all heads/cam cars? If so, that would be nice to know, indeed.
