941 should they stay or go
Old Jun 5, 2002 | 01:00 PM
SSINFUL's Avatar
Default Re: 941 should they stay or go
Different cams each create different harmonics in different places in the valvetrain, especially in the springs. For that reason, every time you change cams, you should change valvesprings.
Old Jun 5, 2002 | 06:36 PM
AlonzoVersion 1.0's Avatar
Get rid of them.Bigger cam means better springs.
Old Jun 5, 2002 | 09:05 PM
MelloYellow's Avatar
Get rid of them, go to 918's.
Old Jun 5, 2002 | 10:10 PM
DenzSS's Avatar
Get rid of them. A buddy of mine broke a 941 with his TR224 a couple of months ago. I think he had about 5K on them. Easy to change out and a lot better than breaking one.
Old Jun 6, 2002 | 12:43 AM
CRASH 02's Avatar
Default 941 should they stay or go
I have a set of comp 941's on my heads and am most likely going to go with the Thunder 224 cam. The springs currently have about 1K on them. The question is, should I go ahead and get rid of the 941's for a set of 918's. Or will the 941's be alright? Thanks
Jason
<small>[ June 05, 2002, 12:48 PM: Message edited by: CRASH 02 ]</small>
Old Jun 6, 2002 | 02:43 AM
Beeler422's Avatar
Back in the staging lane
for no more than they cost, get the 918's.
Old Jun 6, 2002 | 03:27 AM
Tekhombre's Avatar
CRASH 02, I would call Thunder Racing and ask them what spring works best on that cam.
I would stay away from the 941 on the LS1/LS6, nothing wrong with them on other applications such as L98 or LT1 depending on the cam. The 918s we use up to a 224 cam with no more than .570 lift. For more aggressive cams we use a dual spring setup that requires no seat cutting and clears the stock rockers.
Julio.
Old Jun 7, 2002 | 01:15 PM
thebadbat's Avatar
Jason,
Go with the 918's.....
Better safe than sorry! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
BTW: I SAW THAT!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ June 07, 2002, 01:16 PM: Message edited by: thebadbat ]</small>
Old Jun 7, 2002 | 01:20 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd definitely replace them with 918's. A local guy that lives in Plano has had the 941's for over a year now. One broke on him earlier this week, and it actually jammed so that it would not allow the valve to open. I'm running .581" lift w/ the 918's, and so far so good (knock on wood!).
__________________
Old Jun 8, 2002 | 01:16 AM
SSBoy's Avatar
have hadmy 941's in for over 10K miles, with no problems whatsoever!! reving the car to 6600 rpms too. I've used both the comp cam 212/218 525 lift and the TR 224 566 cam with these springs. i guess they work for me.
Old Jun 8, 2002 | 03:19 AM
CRASH 02's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by thebadbat:
<strong>Jason,
BTW: I SAW THAT!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Damn <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Jun 12, 2002 | 01:55 AM
Kevin's Avatar
Ive used them for over a year also with a T1 and alot of 1/4mi passes on them with no problems.
Kevin
Old Jun 12, 2002 | 07:55 AM
Ben99Z28's Avatar
941 has a maximum lift of 0.500, most aftermarket cams are rated at.530~.590 lift so it's pretty much a time-bomb and ready to go kaboom if you're still running them with your T1/B1/TR224 or any other popular cams with .500+ lift. check out the 941 specs here: http://www.compcams.com/catalog/306_307.html
use the 918, it's rated at around .600~.625 max lift.
Old Jun 12, 2002 | 05:42 PM
DropTopTerror's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Catfish:
<strong>941 has a maximum lift of 0.500, most aftermarket cams are rated at.530~.590 lift so it's pretty much a time-bomb and ready to go kaboom if you're still running them with your T1/B1/TR224 or any other popular cams with .500+ lift. check out the 941 specs here: http://www.compcams.com/catalog/306_307.html
use the 918, it's rated at around .600~.625 max lift.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Dude... the .500 max lift is at the small block chevy install height... 941's are not LS1-specific... since the LS1 has a taller install height... we have more room to work with... see NineBall's reply to your other post...
BTW, I've been running my 941's with my T1 cam (.558/.558 221/221 112lsa) for 45,000 miles... couple of my stock lifters recently took a dump on my T1 and took it out... I now have a .574/.574 222/222 114lsa cam with my same 45K mile 941's and they are just great... the old batch of 941's are just fine...
Evan
