MS4 and cam help...
[QUOTE]
Did ur friend have a built up tranny or rear end in his car. Was the motor stock and do u need a stall in ur car with a cam swap.
Thanks
Thanks
A stall makes it easier because it slips more than ur stock TC.....On ur stock TC and a cam like the MS4 its gonna surge pretty bad and wanna push thru ur brakes. Ur gonna be standing on the brakes at stop lights.
you really need to get that TC first before that cam in my opinion, i never really understood why you needed those things until i jumped head first into a cam only MS4 A4 deal. the car dosnt have any power taking off and the part throttle bucking under 2100 rpm's is noticable. i'm getting about 10 mpg (sucks i know but i wasnt getting more than 17 before i started modding it) also make sure you have a free flowing exhuast...your cam is going to want it. let me see...what else.... oh yeah expect the car to smelly gassy at idle in park, with such a big *** overlap it tends to leak fumes out at idle. other than the TC, i'd get the rear gears done too and be set. Thanks
Ray
