Why not Torque??
Andy
J.
Shane
Joe.
<small>[ June 09, 2002, 03:10 PM: Message edited by: JPR ]</small>
TQ is my Friend <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong>How come everyone cares about HP? Torque I thought the person who could make torque on the top end wins? Doesn't the dynomometer measure HP based on torque? <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Torque on the top end basically is HP.
With 2 cars...If you have the most torque on the top end then you have the most hp.
Basically tourque is how hard/force the crank twist. And HP is just tourque at a given RPM.
The harder the crank twist(more force) at higher , or a certain Rpm the more HP you have.
For instance, if you still have 558 ft lbs at 5000 rpm, then you would be making more HP than a car that makes the same 558 ft lbs at 3500 Rpm given if you could keep your tourqe higher thoughout the whole range.
(Which in this situation you most likely would unless the tourqe just fell of REALLY HARD after that point and the other car could hold it's tourqe longer.)
<small>[ June 10, 2002, 12:55 AM: Message edited by: Rpm2800 ]</small>
<strong>The argument really means nothing. HP is a funtion of torque. Torque is the actual force of "twist" from the crank while HP is that force per unit of time. Just try and make the most torque for any given RPM an you have done your job. Try and make the most HP for any given RPM and you have also done your job. You've done the same thing in either case. That's why it is important to see the entire power and torque curve to really know the "personality" of an engine. It is usually when people infer or draw conlusions base on a peak HP or TQ number that they get into trouble.
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">WOW! I seriously couldn't have said it any better. That brought tears to my eyes. This is all that needs to be said right here, folks. Good job, Shane.
