2001 Z06 cam specs
Old Jun 12, 2002 | 06:49 PM
SS Escalado's Avatar
Default 2001 Z06 cam specs
does anybody have the cam specs for this bad boy. I need the duration, lobe seperation adn the lift. thanx
Old Jun 12, 2002 | 07:35 PM
new-LS1's Avatar
Default Re: 2001 Z06 cam specs
Here you go buddy:
Stock cam information for the different years:
C5's
1997-00 LS1 C5 202/210; .472/.479; LSA: 117 Base circle: 19.7mm
2001-02 LS1 C5 198/208 ; .500/.500; LSA:115.5 Base circle: 19.7mm
2001 LS6 C5 Cam: 204/211; .525/.525 ;CL:118/114; LSA:116.0; Base Circle: 19.3mm (-0.0158")
2002 LS6 C5 Cam: 204/218; .551/.547; CL:120/115; LSA:117.5; Base Circle: 19.0mm (-0.0276")
Chevy Hot Cam 218/227; .525/.525; LSA: 112
F-bodies
98-00s had a 202/210 Dur @ .050, .496/.496 lift , 116 LSA or pretty close to those specs.
01-02s had a 198/197 Dur @ .050, .478/.478 lift, 115 LSA
Old Jun 12, 2002 | 07:51 PM
SSINFUL's Avatar
Y'know, I'd about pay somebody to actually measure these cams.
My '98 Helm manual says my Camaro has the .472/.479 valve lift (net lash-No adjustment) Pg 6-234. But! On 6-232, it says my camshaft lobe lift is .292/.292. Multiplied by 1.7 (rockers) = .4964/.4964. Which is it? And, how can they be different (zero lash)?
Pace http://www.paceparts.com/product.asp?0=243&1=250&3=1029 says about the '01 LS6 cam: This camshaft is original equipment in LS6 Vortec engines. It features .525" intake and exhaust lift. 217 degree exhaust duration at .050", 207 degree intake duration at .050", and 116 degree lobe bolts...
