Help me with initial start up paranoia after DIY engine swap
This was my first EVER attempt at an engine swap. I went slow, used assembly lube, correct torque specs etc...
I reused my old lifters and heads. I installed the TR230 111 cam w/ stock length hardened PRs and 918s, tit. retainers.
So here's my paranoia:
Car gets very hot
Valvetrain noise
low lull from the tranny while driving.
Things I think I did wrong:
I didn't purge air from the coolant system. (I'll try that in the morning)
I didn't match the flexplate to the crank flange when I put it on. Could this cause the lull from the tranny? Out of balance?
The valvetrain noise doesn't seem excessive. My Hotcam didn't make this much noise. Is this just normal for this cam?
Please help.
