402 block
Old Feb 10, 2007 | 01:12 PM
Honda Hunter's Avatar
Default 402 block
How much does the block alone wiegh?
Old Feb 10, 2007 | 03:15 PM
wyndzer's Avatar
Are you speaking of an LS2 block? (Aluminum 6.0 block) It's basically the same weight as an LS1 block.
Old Feb 10, 2007 | 03:17 PM
actually yes. Would you say it wieghs 70lbs or less?
Old Feb 10, 2007 | 03:20 PM
wyndzer's Avatar
*edit*
110 lbs. for the block alone! Long blocks usually weigh around 375-390 lbs.
Old Feb 10, 2007 | 03:22 PM
Block alone I'd say 175-200 lbs Long blocks usually weigh around 375-390 lbs.
Ouch. I was way off. Thanks for the info.
Old Feb 10, 2007 | 03:25 PM
wyndzer's Avatar
recheck my post.
