bigger rockers and valve spring wear?
Old Jun 13, 2002 | 11:59 PM
hondakiller's Avatar
Default bigger rockers and valve spring wear?
now this may seem like a dumb question but if you go with a milder cam and make up for it with bigger rockers is the valve spring wear the same as if i went with a more aggressive cam on stock rockers?
Old Jun 15, 2002 | 07:18 PM
steve's Avatar
Default Re: bigger rockers and valve spring wear?
i would stay with the stock 1.7 ratio.
the cams are made to use the 1.7 ratio and going higher in my opinion might over accelorate the valvetrain...
stay with the tried and true method and youll be ok.
steve frank
