h/c swap info.
Old Feb 11, 2007 | 02:46 PM
2002/ws6's Avatar
Default h/c swap info.
the h/c swap is coming up in a little bit. i was curious where u guys bought yours, and if any of u guys would know any good places to look at for a good h/c packages.
Old Feb 11, 2007 | 04:22 PM
Cop Car's Avatar
G5x4 and patriot ported 243s
LS2 timing chain
TSP ported LS6 pump
Katech rod bolts
ARP head studs
remove motor out of bottom of car when doing the swap
Old Feb 11, 2007 | 09:18 PM
1baddls1's Avatar
Texas Speed
cnc-ed LS6's & choice of camshaft... call them & speak about what your looking for & go from there
rod bolts not necc unless you plan on spinning above 6500 rpm
also OE head gaskets & bolts unless you plan on changing again sometime soon
Old Feb 12, 2007 | 01:08 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Originally Posted by 1baddls1
Texas Speed
Old Feb 12, 2007 | 01:10 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Depending on your goals and what the intended use of the car. Mine is...
400+ rwhp w/ 6 speed, 12 bolt, 3" steel DS
Not Daily driven, nice days and weekends, occasional track use.
Mods to attain the goal.
SLP cold air kit
Dynatech LT's with out cats
Corsa Cat back
Thunder racing, 230/236 cam @ 112 LSA
Dyno tune
I may do a UD pulley at the same time as the cam since its not doing a job x2
Ive seen it done so thats why I picked these mods.
Old Feb 12, 2007 | 01:25 PM
HAMRHEAD's Avatar
Check some of the speed inc or TSP setups.
Old Feb 12, 2007 | 02:03 PM
mike#9's Avatar
Look at the Sponsors Sale Section and Group Purchase Section. You should be able to find some great prices there. Also keep reading in the Internal Engine section. Gather as much info as you can, and learn as much as you can. Plan 2 or 3 times....go over all options and scenarios. Get a firm grasp on what you want the car to do, and what direction you want to go in.........and mod 1 time.
