605/609 Lift cam...
Old Feb 11, 2007 | 09:11 PM
TheBiz's Avatar
Default 605/609 Lift cam...
any piston to valve clearance issues with a 2.05/1.6 valved head?
Old Feb 11, 2007 | 09:14 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You need to post the duration. That can be more important than the lift for PTV clearance. However, nothing is a substitute for actually checking with clay.
Old Feb 11, 2007 | 09:19 PM
Thimble's Avatar
The lift doesn't matter...but if those lift values are XE-R lobes, that would be a 238/240 cam, and unless the LSA is extremely wide, no way that will clear with valves that big.
Old Feb 11, 2007 | 11:06 PM
TheBiz's Avatar
It will be a comp 54-448-11. 238/240 on a 112. I was afraid I would have issues with that. So the general concensus is no worky huh? Damn, I just found that cam for a great deal too.
