what does "package" mean in "heads/cam package"
Old Jun 20, 2002 | 10:33 PM
MeanWS6's Avatar
Default what does "package" mean in "heads/cam package"
Do you get to choose your own cam? Do new rods, pistons, retainers, springs come with the package? Or do they need to be purchased separatly? What else do I need to buy with a heads/cam package such as the ARE setups from ls1speed?
Old Jun 20, 2002 | 10:42 PM
dan98z's Avatar
Default Re: what does "package" mean in "heads/cam package"
Depends on the shop..
Sometimes its heads, cam and springs
Sometimes its heads, cam, springs, retainers, lifters and pushrods
Sometimes its heads, cam, springs, retainers, lifters, pushrods and all the required gaskets and bolts
Usually if it is an installed package, it will come with almost everything you need. Just call a shop up and ask what it comes with and what they can do for you. You will learn a lot more about a shop and who you want to do business with by speaking with them on the phone.
Old Jun 21, 2002 | 07:24 AM
Crazyquik's Avatar
yes
you'll need hardened pushrods, better valvesprings, probably want to upgrade retainers, stock pistons work fine. Heads, cam, intake, valvetrain all fall under the catagory of "top end" while pistons, connnecting rods, crankshaft, and block are "bottom end". As mentioned above, different vendors sell packages of different completeness. You'll also need new headbolts, new head gaskets, and a new crankbolt.
You've got a stall and nitrous, you need headers.
J.
