Comp Xfi Lobes
Old Feb 18, 2007 | 07:51 PM
YankeeVert.'s Avatar
Originally Posted by Ragtop 99
I'd use the XFI 214 lobe and 220 Xer lobe and put it on a 114 LSA. Straight up for a basic mid-range and top end performance or 2* Advance for a little better bottom end.
If you have headers, I'd bump the 214 to the 218 and run with 2* advance. 218/220 114 has -9 overlap. It will idle very smoothly. If you are an A4 with a stock stall I'd go back to your 115 lsa with the 214/220 115 113
tc.
Thanks for the input.
I have a A4 with 3.73 gears and a SS3600 .I also have 13/4 Kooks headers and high flow cats.
