Terminator Heads WARNING...
I'm sure that tsp didnt' intentionally not tell anyone about it, that just doesn't seem right.
A better question would be why did edlebrock not drill the hole so the factory bolt will work without cutting? Unless it's for added strenth around that part of the head, I can't see any reason why the hole is a little shallow.
Did you verify that your intake runners lined up properly with the Edlebrock intake ports? I know the Fast intake has issues, but I'm just curious about the LS6.
we did not encounter any problem with the ls6 intake, when i switch to the fast intake i will look into that to see if there is a issue
Any that I've installed never had problems.
Maybe I should have passed this one up as I do the many others you post in... Like I said, there have been no problems here, maybe I have better eyes than most, or rather...a better working knowledge of engine components. Not every part that bolts-on is a true "bolt-on" in every form, sometimes you have to think a little on your own if installing something unfamiliar.Brian, I know you do tons of installs, its possible yours didn't have any obvious problems until heat cycled. I read in GMHTP (the article chef discussed) that Edelbrock revised the casting to use stock bolts, but I havn't seen any myself just yet. I didn't measure them, but it seems the rockers would rotate CW and CCW pivoting on the rocker bolt itself if they bottomed out, I havn't seen any damage firsthand from running an engine using stock rocker bolts.
I did my motor swap under all the wrong conditions and forgot a few things as a result. In retrospect it was a mistake but you live and learn. I had to do what I had to do and it wasnt the ideal way a swap should be done.
I feel for anyone who got tripped up by this situation. Edelbrock should have provided new shorter bolts with the heads and that would have saved a bunch of trouble. At least now all the new castings we're getting have the bolt hole the correct depth, but I still physically check each head to make absolutely sure there won't be a problem.
Richard
The screen should prevent it from entering the oil pump and doing serious harm.
Thanks
