What NGK plugs
Old Jun 26, 2002 | 02:06 PM
White98Z's Avatar
Default What NGK plugs
With mods in my sig. What plugs to get ngk tr-5 or tr-55
Old Jun 26, 2002 | 02:54 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: What NGK plugs
I'm running the TR-55's gapped @ .050" with great success.
__________________
Old Jun 26, 2002 | 03:05 PM
Patman's Avatar
TR5s and TR55s are the same heat range, their only difference is the preset gap. The TR5s are at about .039, the TR55s are at about .059. You only want to change the preset gap by about .010, so if you're gonna go with about .050" then either plug will work. If you want to go with lower than that, the TR5 is the one to go with, if you want to go higher than .050, go with the TR55s for sure.
