SLP double roller timing chain??
Old Jun 26, 2002 | 03:20 PM
DrowningMan's Avatar
Default SLP double roller timing chain??
Im getting all the parts together for my cam. I haven't heard anything about this and was wondering about it. Is there a better one??
<small>[ June 26, 2002, 03:21 PM: Message edited by: Whatsoil4? ]</small>
Old Jun 26, 2002 | 04:03 PM
SSINFUL's Avatar
Default Re: SLP double roller timing chain??
Plenty o' posts around about this. There is only *one* double roller out there (that I am aware of). It's put out by Rollmaster. SLP sells it. ARE sells it (s'where I got mine). So do some other folks. It's the same piece.
Old Jun 26, 2002 | 04:36 PM
The Emperor Of Darkness's Avatar
would there be any timing issues?? or does it replace the stock one???
Old Jun 26, 2002 | 09:10 PM
SSINFUL's Avatar
Emp: The only timing issues to doing a direct replacement (no other mod like a cam install happening concurrently) would be if ya, for some crazy reason, rotated the cam or crank while doing the install. Obviously, that would seriously mess up yer valve timing.
If you are doing it concurrently w/ a cam swap, then follow the directions (dot-to-dot or "degreeing") as laid out by Raughammer or whoever's directions yer using...
Old Jun 26, 2002 | 09:22 PM
thanks SSINFUL
