Cooling System Pressure?
Old Jun 29, 2002 | 01:10 PM
JP98SS's Avatar
Default Cooling System Pressure?
Anybody know what psi the cooling system is supposed to run at?
Old Jun 29, 2002 | 01:14 PM
NoGo's Avatar
Default Re: Cooling System Pressure?
Take a peak at your radiator cap. I think that should tell the story.
Old Jun 29, 2002 | 01:39 PM
JP98SS's Avatar
Is there any sort of buffer built in? The cap is rated at what....15lbs? Is the system supposed to run 1 or 2 under the rating of the cap? What can pressurize the system other than a leaking head gasket?
Old Jun 29, 2002 | 03:55 PM
SteveD's Avatar
The cap is just a releif valve. The higher the pressure in the system the higher the boiling point will be. How hot do you run the car. Rent a pressure tester and check for a leak.
Old Jun 29, 2002 | 04:44 PM
JP98SS's Avatar
The car isn't overheating when it gets past the cap. I am just wondering what the margin is between the cap blowing and normal operating pressure.
