4.8 and ls1 mix?
Old Feb 15, 2007 | 02:03 PM
txredxj's Avatar
Default 4.8 and ls1 mix?
can i use an ls1 short block with my 4.8?
Old Feb 15, 2007 | 03:38 PM
ChucksZ06's Avatar
yes it will be fine.
Old Feb 16, 2007 | 01:27 PM
txredxj's Avatar
will there be anything that i will have to modify on the ls1 block?
will i need bigger injectors before i do it?
Old Feb 16, 2007 | 03:05 PM
justin b's Avatar
no,the gen3 4.8,5.3 5.7 and 6.0 all are able to swap heads,good luck
Old Feb 16, 2007 | 03:20 PM
txredxj's Avatar
sweet. what kinda compression will i be seeing? will i need to run premium (90 is all i can get around here)?
Old Feb 16, 2007 | 03:33 PM
justin b's Avatar
im not sure try to search it on the forum
