What pushrods? Ok, so, in the near future i'm going to be doing a cam swap on my 1998 T/A. The cam is a 230/232 .595 .598 on a 114lsa. What I need to know is, what length pushrods do I need, and what type should I get. I'm also gonna put in patriot gold duals, a ported ls6 oil pump, and a double roller timing chain. Anything else i'll need to upgrade while i'm in there? |
7.4's |
Ok, that's what I thought. IS that the stock length? And preferred brands/types, or should I just go with comp chromemoly's? |
Originally Posted by 09CPTN Ok, that's what I thought. IS that the stock length? And preferred brands/types, or should I just go with comp chromemoly's? |
Originally Posted by 09CPTN Ok, so, in the near future i'm going to be doing a cam swap on my 1998 T/A. The cam is a 230/232 .595 .598 on a 114lsa. What I need to know is, what length pushrods do I need, and what type should I get. I'm also gonna put in patriot gold duals, a ported ls6 oil pump, and a double roller timing chain. Anything else i'll need to upgrade while i'm in there? |
I have the exact same cam but with milled AFR 205's, and I used the 7.4's. This is a good cam you'll like it. I put down 396@6200rpms on a baseline tune before my DS took a dump. |
© 2024 MH Sub I, LLC dba Internet Brands
