Dyno question
Old Jul 9, 2002 | 08:12 AM
Ozz's Avatar
Ozz
Default Dyno question
Not sure if this is where to post this but I will ask anyway. How much HP loss should I estimate when Dyno was run at 99 degrees and 97% humidity?
Car only pulled 370rwhp with stageII heads 218/222 cam LS6 intake and FLP long tubes, plus all the other bolt-ons.
Ozz
Old Jul 9, 2002 | 08:39 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Dyno question
Dynojets have weather correction factors. You should have received a printout with "actual" HP for that weather, and "SAE Corrected" HP based on a standard set of weather conditions.
SAE numbers are what everyone compares with.
Tony
Old Jul 9, 2002 | 02:08 PM
DenzSS's Avatar
Dynojet's correction factor is very good. Usually, there will be less than 5rwhp variation between the worst weather and the best.
Old Jul 9, 2002 | 02:25 PM
cablebandit's Avatar
hey don't fret dyno numbers....they are great for comparing mods but not much else unless you dyno'd with friends. Just think...on a Mustang Dyno you would've only pulled 345rwhp <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Mph at the track is what you really want to look at.
Old Jul 9, 2002 | 02:39 PM
NastySSoo's Avatar
Thats odd, I dynoed higher (12rwhp) on a mustang dyno than I did on a dyno jet with the same mods?? 1 MADSS was there also and thought the mustang was too high? Oh, well just use them for upgrade #s and its all good.
Old Jul 18, 2002 | 01:11 AM
01DetroitSS's Avatar
Do mustang dynos have corrections for weather also.
Old Jul 18, 2002 | 09:25 AM
DenzSS's Avatar
Mustang Dyno's don't correct to SAE if I remember correctly. Don't they correct to STD?
