Isolating False Knock Exhaust vibration??
I 'might' have some intermittent KR due to a vibration. I always see it in 1st gear & only first gear below 4k RPM.
Any advice on isolating the cause? It's intermittent. Anything I can do other than Race Gas??
Maybe try to account for the sideways movement when the engine torques/turns?
<small>[ July 10, 2002, 07:10 PM: Message edited by: gwj ]</small>
Will try to lift her up and TQ the engine around and listen for rattles.
FWIW, I'm seeing it only in 1st gear only half the time and see about 3* when I do.
Perhaps my Q should be, is there any way to tell from AutoTap if the KR is real or false? Anything that might give it away?
Wouldn't my exhaust rattle in other gears? For those that had exhaust rattle false KR in the past, what speeds/gears/rpm's did it occur at?
Can anyone post a timing table for a 1st gear WOT run for me? Maybe I have too much timing down low.
