Bore and stroke ?
Old Jul 11, 2002 | 11:32 PM
1320's Avatar
Default Bore and stroke ?
Is the 4.8 the smallest LS1 based engine?
If so what is the bore and stroke?
Is it identical otherwise? Heads interchange etc....??
Old Jul 11, 2002 | 11:50 PM
1320's Avatar
Default Re: Bore and stroke ?
Oh yea.....what are some flow numbers for LS6 heads......and c5r heads? just roughly....500, 600 , 700 lift?
And what are the valve sizes? oem and aqftermaket?
What is the oem rod lenght? Are they all the same? 4.8, 5.3, 5.7, 6.0?
And are logher rods readily available?if so how long are they?
<small>[ July 11, 2002, 11:51 PM: Message edited by: 1320 ]</small>
Old Jul 11, 2002 | 11:53 PM
Richard@WCCH's Avatar
Here's the run down on the entire engine family. This is according to GM's web site.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
Vortec 4.8l 293.35cid Engine code: LR-4
Bore = 3.780” (96.01mm) Stroke = 3.268” (83.00mm)
Compression Ratio = 9.5:1
Factory Rated Horsepower = 270
Factory Rated Torque = 285
Vortec 5.3l 325.16cid Engine code: LM-7
Bore = 3.780” (96.01mm) Stroke = 3.622” (92.00mm)
Factory Rated Horsepower = 285
Factory Rated Torque = 325
Vortec 5.7l 345.7cid Engine code: LS-1
Bore = 3.898” (99.0mm) Stroke = 3.622” (92.00mm)
Compression Ratio = 10.1:1
Factory Rated Horsepower = 350
Factory Rated Torque = 375 (equipped with manual trans) 360 (equipped with automatic trans)
Vortec 6.0l 364.13cid Engine code: LQ-4
Bore = 4.00” (101.6mm) Stroke = 3.622” (92.00mm)
Compression Ratio = 9.4:1
Factory Rated Horsepower = 300
Factory Rated Torque = 360
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The cylinder heads are interchangeable with some small differences in chamber and intake valve size.
Hope this answers your questions. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Richard
Old Jul 11, 2002 | 11:58 PM
1320's Avatar
Are all of them the same bottem end set up? 4 bolt mains....with 2 cross bolts....even in the iron blocks?
Are all the main journals the same size? Ie... are the cranks interchangeable?
Old Jul 12, 2002 | 07:35 PM
1320's Avatar
ttt
