What are 2000 LS1 heads worth?
Old Jul 13, 2002 | 11:22 AM
Brian Bowlin's Avatar
Default What are 2000 LS1 heads worth?
There's a guy on my local fbody list selling stock 2000 LS1 heads for $325. I've got a stock '98 LS1 going into a '67 Camaro and I was thinking that they may be worth getting so that I can port the 2000's and swap them out later.
Is this a good deal?
Old Jul 13, 2002 | 06:57 PM
Nasty N8's Avatar
Default Re: What are 2000 LS1 heads worth?
Not bad can find them a little cheaper. But you will need diff. valve covers the bolt pattern is diff.
Old Jul 14, 2002 | 09:39 AM
MDL-01C5's Avatar
I agree w.Nasty-- the heads alone aren't that bad, but adding the cost of the new valve covers, you'd be better off checking Ebay and other places for 97-98's (unless you're OK with swapping the VC's--then I say go for it)
Old Jul 14, 2002 | 11:19 AM
99 Black Bird T/A's Avatar
I've seen 98 heads go for $250 to $275 many times. They are usually cheaper than 99+ heads.
