Bought an M.I.D. block HELP!!!
Old Feb 21, 2007 | 03:05 PM
Stang's Bane's Avatar
Isn't there a difference between the MID and the wet sleeves????
Old Feb 21, 2007 | 05:18 PM
11 Bravo's Avatar
No. The Darton MID sleeve is a wet sleeve design. It's what I'm running.
Old Feb 21, 2007 | 06:00 PM
URLOSN's Avatar
sorry, it was RDI who did the sleeving
Old Feb 21, 2007 | 06:21 PM
11 Bravo's Avatar
Don't they specialize in Ford engines?
Old Feb 21, 2007 | 07:19 PM
URLOSN's Avatar
i believe so, not real sure. but the guy was really nice about it, and is giving me my money back, and i am sending the block back tomorrow. i'm looking at a dry sleeved LS1 now, anyone have much luck with them?
Old Feb 21, 2007 | 10:25 PM
Beast96Z's Avatar
Don't do that either. Dry sleeved LS-1's aren't great either. If you want to go dry, use a LS2 case. The dry LS2 should handle what you want to do.
Old Feb 21, 2007 | 11:19 PM
URLOSN's Avatar
what's wrong with the dry sleeved ls1??
Old Feb 21, 2007 | 11:52 PM
Beast96Z's Avatar
The area between the cylinders of the LS1 block is hollow, or otherwise filled with coolant. This leaves very little room to work with when trying to increase the size of the sleeve. That's why LS1 blocks are primarily used for the MID set-up. On the LS2 case, the area between the cylinders is solid aluminum, so it gives more stregnth when increasing the sleeve size. If you could find someone to properly dry sleeve a LS1 (doubtful), the max reccomended bore is only 4.060". Max bore on the dry LS2 is 4.185". Why sell yourself short? I'll make this super easy for you. Sleeving is a tedious process, and I would only trust 2 people to do it. That's Steve at RED, and Katech. Neither of these 2 will dry sleeve a LS1 case since the introduction of the LS2 case. That should tell you enough right there. If you don't use one of these 2 for your sleeving, your taking a MAJOR gamble. I always reccomend going to Steve because you get "extras", such as a longer sleeve, for running long strokes, plus, the Darton sleeves are a better material and can hold a larger over bore. My reccomendation to you, is to call Steve and order a dry sleeved LS2 case using the Darton LS7 sleeves. This is the most cost effective/sturdiest case for the money. Here's a list of blocks you can sleeve:
1. LS1 block using MID sleeves (strongest by far)
2. LS2 block using LS2 Darton sleeves (4.160" max bore)
3. LS2 block using LS7 Darton sleeves (larger bore potential 4.185" max)
4. LS7 block using LS7 sleeves (unrealistic uless you already have a LS7 block)
Old Feb 22, 2007 | 05:31 AM
URLOSN's Avatar
ok, thanks man, that helps
Old Mar 3, 2007 | 04:52 PM
vtanju's Avatar
Originally Posted by 96 Comp T/A
You ought to silence your pie hole if you don't know what you are talking about. When you wet sleeve a block there isn't any auminum material left between the sleeves at all. The entire inside of the cylinder case is cut out. The cylinders use the outside of the case and machined flats on each side to locate them selves.
hi,
i was only talking about the thin wall between the breathing bays cracking, i know that there is no aluminum left between the liners above the seat, and about your comment about me not ever seing a MID block you are making useless assumptions, we make the liners and machine the block here ourselves, not buy it straight from DARTON. finally i can make any usefull comment that i want as long as i dont offend anyone maybe you should keep this in mind since i was correct about the LS6 block not being an ideal choice for MID sleeving, and maybe you are the one who has a few hearsay ideas about everything but not sure about anything. what do you say? APOLOGY ACCEPTED.
and by the way how much are you willing to bet?? i need some cash these days!
take care
Old Mar 5, 2007 | 04:57 AM
427LS1's Avatar
sorry one thing i missed, do the 5.3L blocks have the windows or not?
