Car is about done thanks for all the help
Old Jul 17, 2002 | 05:08 PM
masmith's Avatar
Default Car is about done thanks for all the help
Thanks for all the help with my questions and a big thanks to Shane (XtraCajunSS) who talked with me on the phone for awhile. Well should be running in a few weeks waiting on the tranny. Here is a run down of what I ended up going with LQ4 block 4.030 bore Lunati 4.125" crank, some ross pistons, GTP stage 82 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> heads solid roller, TH400 with a brake. Full BMR setup and a 9" with 4.11's and a spool. I hope to make it to the MMRA race if we get everything tuned out.
Sean
Old Jul 17, 2002 | 05:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Car is about done thanks for all the help
Sean you ever made it to a MFBA/US41 track rental?
What tires will you be running? Using LS1 Edit?
Old Jul 17, 2002 | 05:25 PM
masmith's Avatar
Hey John yea back when the car had boltons I drove up there but it ended up raining up there. I will be coming up there for sure once the car gets done. I will run 26" hoosier's at first maybe step up to alittle more if need be. I will also be running a TNT direct port kit probably 200 to a 300 shot. Yea we are going to use LS1 edit and see if that works out, you used LS1 edit on yours didn't you? I heard it is still limited in what it can do to 98's did you guys run into any troubles?
Thanks
Sean
