Comp Cams 850-16 lifter install question
Old Jul 18, 2002 | 10:48 PM
Phil99vette's Avatar
7 Second Club
Default Comp Cams 850-16 lifter install question
Hey I got a question about installing these. I was talking to a buddie and he said I needed to use some .030-.040 shims under the rocker rail because the preload would be more than what is required by comp cams. Does this make sense or should I install them according to the stock specs?
Phillip
Old Jul 19, 2002 | 07:06 AM
y2khawk's Avatar
Default Re: Comp Cams 850-16 lifter install question
If they like less preload you're better off going to a shorter pushrod than trying to shim the rockers.
I don't even think you can safely shim stock rockers.
FWIW, with my cam and slightly milled heads i had to go to a 7.3 pushrod to get my preload on stock rockers back to where i wanted it.
Did he give you a number on preload?
