Need some help!!!
Old Feb 20, 2007 | 11:02 PM
juicedls1's Avatar
Default Need some help!!!
Hey, i purchased the comp pro magnum rocker kit: 1.75 rollers, guideplates, pushrods(7.4-5/16), studs and polylocks. My question is the adjustment procedure the same as the cranes cause i talked to the tech help from comp cams and they said the adjustment procedure was the same as the older style smallblocks (take the zero lash out then 1/2 turn) I want to do this right the first time so i dont have to take it apart again! Thanks N Advance!!!
Old Feb 22, 2007 | 05:57 PM
juicedls1's Avatar
Anyone got just a little info? I guess this is a weak subject, not to many people know anything bout it i guess!
Old Feb 22, 2007 | 06:07 PM
brad8266's Avatar
No lash adjustment on LS1's. You tighten each rocker nut to 22lbs-ft when the valve is fully seated in the bowl. Its very simple.
Old Feb 22, 2007 | 06:39 PM
juicedls1's Avatar
I have the adjustable kit from comp it changes the factory non adj. to adj! Thats why im confused on how to adj them!
Old Feb 22, 2007 | 06:41 PM
brad8266's Avatar
oh ok
