RACING FUEL ANYONE?
The highest unleaded that I have seen around here is 100 octane.
Anyway unless you are running very high compression or a high boost application "racing fuel" is not going to make more HP.
Unleaded racing fuel can be had up to at least 106 motor octane (which would be somewhere around 112 by the R+M/2 method which is what is used at the pump.) That would be good for even 14:1 engines.
Leaded fuel will not only ruin cats but will also foul O2 sensors in a hurry even if dilluted with unleaded fuel.
Yes, leaded fuel will destroy your cats and o2 sensors in a hurry...
yes you can find power in fuel(not only higher octane leaded fuel but other supplements <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )even at stock compression
i mix a fuel that gives me approx 3 tenths and 3.5 mph... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
i have stock internals and the car is relatively stock and our track is 2200 ft ASL and its vegas so its hot!!
check the sig and this is at 3650lbs(me included)
<small>[ July 25, 2002, 02:34 PM: Message edited by: Grease Monkey ]</small>
