weird power problem!
Old Feb 22, 2007 | 08:04 PM
nomorews6's Avatar
Default weird power problem!
my installer just finished installing the heads, cam, intake, pulley & exhaust and said if you turn the key on, the display will not show up, but if you bang around under the dash, it flickers. If you plug in a diagnostics scanner, the lights will stay on. It doesn't show any codes or anything.
help! any ideas? this is a 98 ls1
Old Feb 22, 2007 | 08:14 PM
cowboysfan's Avatar
check all connections and ground wires from under the dash. did they have to do any kind or work under the dash?
fuerzaws6
Old Feb 22, 2007 | 08:29 PM
nomorews6's Avatar
no - i don't think he had to do anything under the dash.
Old Feb 22, 2007 | 08:35 PM
DaddySS's Avatar
Have them check the ground on the back of the left head. Strange electrical issues are usually a sign of a bad ground.
Old Feb 23, 2007 | 10:02 AM
moeZ28's Avatar
Yeah the ground on the back of the driver side head. there is 2 separate wires, but 3 eyelets that must be grounded. I had this problem before.
