2000 LS1 oil pump
Old Feb 24, 2007 | 03:17 PM
vtirocz's Avatar
Default 2000 LS1 oil pump
What's the difference between the '00 LS1 f-body oil pumps and the oil pumps put in during the '01-'02 model years? I have 42k miles on my Z28 with no issues and wanted to see if it is urgent to upgrade the oil pump.
Thanks,
Jim
Old Feb 24, 2007 | 03:50 PM
ChucksZ06's Avatar
If it is working well leave it alone.
Old Feb 24, 2007 | 03:55 PM
2000Hawk's Avatar
If you ever plan on doing a cam swap in the near future the oil pump is on of those things that you might as well change while your in there. Many people go and change to a ported LS6 oil pump. Got mine from Texas-Speed
-Joel
Old Feb 24, 2007 | 05:23 PM
vtirocz's Avatar
what exactly is the difference between the two?
Thanks,
Jim
Old Feb 24, 2007 | 06:34 PM
brad8266's Avatar
Thanks,
Jim
Nothing really, some people say the pre 01's are less reliable for some reason.
Old Feb 24, 2007 | 07:27 PM
david vericker's Avatar
Thanks,
Jim
I have the original 98 oil pump in my vette. Have made numerous changes throughout the years - 2006 setup made just over 500 rwhp (H/C I25 shot) that entails hundreds of passes down the 1320 over the years. Who knows maybe I was just lucky.
Will be running a 383 stroker for 2007 - putting in a Melling 10296 can't push my luck to far!
Old Feb 24, 2007 | 07:29 PM
keliente's Avatar
It's something you don't really replace unless a) you are already having problems or b) you are doing a cam swap...the oil pump has to come off anyway so most people just change it while they're in there.
