Ls6 heads on Ls1 with TREX cam
Old Feb 27, 2007 | 08:22 AM
Jbmoney21's Avatar
Default Ls6 heads on Ls1 with TREX cam
Im looking at either running the TREX or MS4 cam.
Here is my question i know they are both really close as far as PTV clearance goes and the TREX actually almost pushes it TOO close. If i put some LS6 heads that havent been milled will my PTV clearance be even a greater problem. What im asking is are the LS6 heads valves longer, casting shorter or anything that could make the PTV clearance worse?? I know the Combustion chamber is a tad bit smaller but that should only factor in comp ratio. Any help is appreciated
thanks
Old Feb 27, 2007 | 09:08 AM
01350ss's Avatar
Nope. You'll be fine. I'm running "off the shelf" z06 heads with my trex cam. I'm also using the fast 90 and a nw 90 tb. I putting down 480 through a 6 speed and a 4.57 spooled 9" with full exhaust. It's a fun ride. No fly cutting needed.
Old Feb 27, 2007 | 09:09 AM
SVT THIS's Avatar
You can run a Trex cam on stock valved LS6 heads. TSP has a good set of PRC CNC LS6 heads that will work with the Trex cam. However, you'll be leaving a lot of power on the table by not flycutting the pistons and not milling the heads to get your compression in check. You would be better off getting a small cam and milling the heads or cutting valve reliefs in the pistons to allow for better compression.
