Intake Part Number Questions!
We always refer to numbers that are cast or molded into the part as an "ID" or casting number. More often than not this number has nothing to do with the actual part number for ordering a part. You could actually go to a GM dealer and order a "casting number" that you found off your part thinking you were going to get what you needed, and you just might receive a fender for a Buick because that "casting number" just happened to be a good "part number" in the GM system! So always be careful when looking at casting numbers and trying to order that part.
Most times, a 'casting' number is NOT the 'part' number. Keep in mind that your 2001 LS1 came from the factory with a LS6 intake.
Here are the part numbers:
12561269 Intake for 98-00 F-body
88890523 Intake for 01 F-body
88890524 Intake for 01 Vette (LS1& LS6)
Not sure of the casting numbers. Hope this helps.
