Coolant capacity LS1
Old Aug 11, 2002 | 10:08 AM
Brent's Avatar
Default Coolant capacity LS1
If you were to drain a LS1 engine of all the coolant how much would drain out? 1 gallon, 2, 3?
And...how much of that does the throttle body retain (if its not bypassed)?
Thanks
Brent
Old Aug 11, 2002 | 10:23 AM
Hugger's Avatar
Default Re: Coolant capacity LS1
I am interested in knowing this as well.
-Josh
Old Aug 12, 2002 | 12:35 AM
DERTY's Avatar
The Bull
Throttle body only holds an ounce, if that. It's just a pass through line with no reservoir.
My H/C Install had about 3 gallons of coolant come out. There is more in the block though. When you put coolant back in I just took two gallons of coolant and mixed it with two gallons of water (a little more coolant than water) and put it back in.
