Bottom End
Old Aug 12, 2002 | 06:39 PM
Viper's Avatar
Default Bottom End
Long story, but woke up to no oil pressure one morning....
OK, just did the test for the oil pump; removed filter, disabled ignition and turned it over. No oil coming out where the filter was. Dealer already replaced sending unit on the manifold. So I'm going to buy a Katech oil pump.
I just read on ls1info how to do it, but to properly 'inspect' the bottom end of the car am I going to have to raise the motor off the mounts or pull the engine entirely? I mean to pull the oil pan further than the install has it written.
I have had a bunch of posts regarding a new shortblock, but figured I need to see what if any damage I have to the bottom end.
Which will lead to a myriad of other posts regarding whether it's cheaper to rebuild the stock bottom end ( say new rings, bearings, turn the crank and get the block honed up ) vs. buying a new short block ( $2500 ).
Old Aug 12, 2002 | 08:40 PM
Viper's Avatar
Default Re: Bottom End
ttt
Old Aug 12, 2002 | 09:01 PM
H82BBad's Avatar
I spoke with Katech and they said you can change rod bolts with the engine in the car. I dont know if you take the pan off without lifting the engine up some though.
Old Aug 12, 2002 | 09:06 PM
Viper's Avatar
Well, I figure I just want to pull the cover and look. If things are messed up I assume I would want to pull the engine at that point. But it is nice to know you can change the rod bolts from underneath.
Old Aug 13, 2002 | 11:27 AM
Viper's Avatar
ttt
Old Jul 6, 2010 | 11:03 PM
xjaguar's Avatar
I know this thread is old, but it's always better to search than to ask again, (and I am searching how to do this) so, this is how you do it without taking off the engine:
http://www.ls1engine.com/tech/98-02-...-bolt-install/
