Heads cam numbers
Old Mar 5, 2007 | 09:27 AM
ssfast99's Avatar
once you clay the piston you'll find out.
Old Mar 5, 2007 | 09:32 AM
brad8266's Avatar
438 isnt bad considering you are running a 4.10 gear which will lower your dyno numbers a bit.
Old Mar 5, 2007 | 12:01 PM
bwil6488's Avatar
I also have the 59cc heads with 2.055 1.57 heads. I did no fly-cutting. But I did rotate the assembly to verify ptv clearance. It was close with the 7.45 pushrods, so I went with 7.4s. If you go with this setup be sure to let me know your results.
