Could a cam cause high idle in gear?
Old Aug 15, 2002 | 03:51 PM
98TAauto's Avatar
Default Could a cam cause high idle in gear?
i posted this in the programming section but havent gotten a reply:
well my car seems to idle sorta high in gear now. Im not sure if it came from the cam install or not. But my idle in gear rpms are set at 875 so should i bump them down? Its the same as my park idle setting, but as soon as i put the car in gear it jumps up to like 1000-1200 or so. The car wants to pull ahead with my foot off the gas.
i have the vig3600 also, but i know it wasnt this bad till after cam went in.
should i just bump my idle rpms down some on edit? or is there something else?
