224/224 vs. 224/228
Old Mar 1, 2007 | 10:15 AM
dbirdz06's Avatar
Default 224/224 vs. 224/228
All else being identical...what are the different characteristics of a cam with the same intake/exhaust duration versus a cam with an extra 4 degrees of exhaust duration? Both are very common, and I was just curious what the benefits of one are over the other.
Old Mar 1, 2007 | 10:58 AM
SSpdDmon's Avatar
A few years back, cam designers noticed that they could get more power by increasing just the exhaust duration. There was an article I read about it in last year, but I've long since forgotten where that was...as well as the "whys."
Old Mar 1, 2007 | 11:05 AM
LS1W66's Avatar
Split duration Cams have been around for decades
The extra exhaust duration was usually done to help a weak flowing exhaust port.
Old Mar 1, 2007 | 11:22 AM
speedshifterNC's Avatar
new to the game but I heard LS1 stock heads had big exhaust ports so would it make more sense to inc the intake duration?
Old Mar 1, 2007 | 11:32 AM
thehammer69's Avatar
A single duration will most likely have a slight stronger midrange but sacrifice top end and revs. Single durations are probably better for weak rod bolt having LS1's in heavier F-body's. Your lighter Z06 vette and LS6 will work well with a larger exhaust duration. Let that LS6 rev.
Hammer
Old Mar 1, 2007 | 01:22 PM
eamador11's Avatar
Very similar cams, i doubt you will see a major peak HP difference. if you get heads like AFR 205s then go with the 224/228 because the cam was specd out for those for a killer combo
I had a 220/220 and there is hardly a difference in idle.
Old Mar 1, 2007 | 04:42 PM
finallygot1's Avatar
Is the 224/228 a CompCam XR277HR by chance?
