mti s1 cam with nos question
Old Aug 16, 2002 | 07:49 PM
OSR 1's Avatar
Default mti s1 cam with nos question
if any one could help it would be a big help
422 motor with a s1 cam chris at mti told me to just line the dots and i would be fine
but after checking the cam card it said to run it at 108 so i check it and it was at 114 so i need some input from you guys the car is a auto
thanks
Old Aug 17, 2002 | 04:11 AM
AlonzoVersion 1.0's Avatar
Default Re: mti s1 cam with nos question
Nervous huh?So was I my first time.Just line it up dot to dot and you will be fine.Its the only to put the cam in correctly with a stock chain and gear.
Old Aug 17, 2002 | 07:16 AM
OSR 1's Avatar
drilling the gear is no problem and i have plently of bushings just trying to find out if 108 is a good starting spot
thanks
