Engine Failure!Diagnosis opinions wanted.
Good news is I ran a new best:
12.11 at 116.27 (1.8960ft)
The bad news is on the next run right after the 1-2 shift the engine stumbled and then died.At this time white smoke billowed out the exhaust as I costed to the end of the track.
When I pulled over I checked the Exhaust tips and there was coolant and Oil.
When I pulled the oil cap it was all foamed up with oil and coolant.(I was thinking head gasket)
This is the part that I think is going to be really bad!The engine still cranks so I think the crank is O.K.but when I pulled the dip stick it got stuck and I had to muscle it to get it out.When I tried to put it back in it runs in to something about 6 inches before it bottoms out.
Everything looked good until that run and the car was running damm strong.
Is it head gasket failure,Did the(Stock) oil pump take a dump?
Halp a fellow LS1er out what went wrong and what am I looking at?
This car is my daily driver so I am pretty much screwed!
Thanks for your help all opinions wanted!
Mods are below and in signature:
+ Tr 224 cam and Hooker long tubes
<strong>This is the part that I think is going to be really bad!The engine still cranks so I think the crank is O.K.but when I pulled the dip stick it got stuck and I had to muscle it to get it out.When I tried to put it back in it runs in to something about 6 inches before it bottoms out.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't crank it any more. If you want to save the crank... Drain the oil, I bet you'll find more siliconized aluminum, than a good day in a Bauxite mine near Dow Corning.
Good luck with new one.
