cam & valvespring?
Old Aug 21, 2002 | 04:49 PM
justin sutton's Avatar
Default cam & valvespring?
Wondering are most of you degreeing in the cam or lining the dots when installing a cam.I also want to know if any body is setting the height on the 918s or just putting them in.
Old Aug 21, 2002 | 04:55 PM
jmX's Avatar
jmX
Default Re: cam & valvespring?
If the cam is ground properly (can verify this with a cam doctor) you will be fine just doing the dot to dot install. You'd have to buy an adjustible cam gear if you wanted to degree it in anyways. Some sponsors ship out their cams only after they cam-doctor them so that you know its correct.
