what should normal misfires be with cam?
i get anywhere from 8-33 on every cylinder off and on at idle
i just replaced my broken 918 and was logging things at idle. The cyl it broke on was showing the same as the rest bascially. One minute it shows 12misfires, the next time around its 28
but i htink this is normal for any cam at idle right??
I have TR-6's with a 224 .563 114 cam
<strong>Slowhawk you are a M6 with a higher stock idle. He is an A4.
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OOPS <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
but i checked after i went and most of them went away under normal driving.. maybe 1-2 here and there but nothing extreme. They went away as my rpms starting going up so i guess she's normal <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
thanks everyone!
BTW, if the misfires are concentrated on a couple cylinders, such as ones that had the springs break, you may have real issues. If they are random through most of the cylinders, you're probably OK.
<small>[ August 26, 2002, 08:04 AM: Message edited by: Ragtop 99 ]</small>
<strong>HD: What is your idle speed? If you are around 900, the misfires should be minimal. They should go away completely at 1000 - 1100 rpm with your cam.
BTW, if the misfires are concentrated on a couple cylinders, such as ones that had the springs break, you may have real issues. If they are random through most of the cylinders, you're probably OK.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Joel, im around 850 idle. When i get up to 1200 i dont think i have any.
But also i made sure to check i didnt have them around the 4cyl(broken spring)
atfirst i was freaking out cause it was showing 28 or so misfires there off and on. Then cyl 3 had them and they rambled around. I noticed after i got back from driving my misfires at idle came down to like 0-12. I didnt even have any 20's showing
