Anyone build a 422. Internal questions.
Old Aug 25, 2002 | 08:26 AM
Redline-Motorsports's Avatar
Default Anyone build a 422. Internal questions.
Interested in knowing which pistons and rods you where using and some details about the pistons.
I am using a 6.125" rod and assuming a deck height of 9.240". Block will most likely be decked .002-.003" for cleanup after sleeving. I am trying to determine the compression height of the piston based upon the piston .008-.010" out of the bore.
I plan on using JE Pistons.
Any credible feed back would be appreciated.
