procharger 9"s boost numbers
Old Mar 5, 2007 | 10:27 PM
kngkahious's Avatar
Default procharger 9"s boost numbers
what kind of power do the prochargers really make on a stock engine 9#'s and a p1sc what times do yaw cut.the book says 500 but i dont think that it's that much.maybe 400rwhp its a 2000 ta 6 spd
Old Mar 6, 2007 | 07:15 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Mine made 489 rwhp with 6# of boost on my old completely stock engine thru a 6-speed.
New setup in the works is going to be able to handle more boost. Hoping for 600 rwhp
Old Mar 6, 2007 | 11:24 AM
Tuner@Straightline's Avatar
We just finished up a 2001 A4 C5, only mods were FLP Long tubes, MagnaFlow cat back, and Comp Cam 26918 springs with an A&A Corvette Vortech kit. At 9lbs of boost, at 6200rpm, it made 476rwhp on a Mustang MD-1100SE dyno. Prochargers usually have a higher step up rate, and are a little more efficient, hence make a little more power.
Old Mar 6, 2007 | 02:38 PM
Irocss85's Avatar
Ive installed a few of those , but never on a bone stock engine.
on an A4 with 3:23 gears, longtubes/cat'dypipe, catback, that one put down 428 RWHP on a mustang dyno.
another was a 6sp. car with midlength tubes, offroady, carback, inj.s, it put down 44X RWHP mustang dyno again both cars were around 7-8psi. this car later upped to 10lbs and a 224 cam and put down 489RWHP mustang with the extra boost and better tuning.
Old Mar 8, 2007 | 11:23 PM
kngkahious's Avatar
i was wrong the car has 42# injectors lt headers and full exhaust it is a 6spd there are a few other things done to it also but those are the biggest.it should be close to 485 whp if im right .what u think
Old Mar 8, 2007 | 11:24 PM
kngkahious's Avatar
it is also an 8# pullie
