URGENT, need help with assembling the bottom end
Old Aug 27, 2002 | 11:32 PM
SlowLS1's Avatar
Default URGENT, need help with assembling the bottom end
Starting to put the bottom end back together and i have run into problems, it seems as tho i have forgotten the correct order of the main caps and direction, i had them labeled but it did not survive the block cleaning <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
What i really need is a good picture showing me what the assembled bottom end looks like, direction of the main caps and order, is it 1-5 front to back or vise versa?
any pics showing me will be of assistance!
I'm really at a lose and can really use some help at the moment. i need to get back it back together, it is a daily driver and it's downtime is killing me
THanks
Brian
www.highperformancetoys.com
Old Aug 27, 2002 | 11:57 PM
cablebandit's Avatar
Default Re: URGENT, need help with assembling the bottom end
cap 1 goes in the front of the motor....the ls1 caps are labled.....they can only go one way i believe but if you have the motor upside down.......the numbers stamped on the caps go to the right side (looking from back of motor to the front)
Old Aug 27, 2002 | 11:58 PM
Jason99T/A's Avatar
I can shift faster than you.
Front (#1), thrust (#3), back (#5)
Old Aug 28, 2002 | 12:26 AM
Jackyl_30's Avatar
from left to right #1, #2, #3, #4, and #5 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://dodgetrucks.org/photopost/data/239Dsc00620.jpg" alt=" - " />
